Hey guys, wonder if you can help me. I have a Core 2 Duo 6600 on an Asus P5K Deluxe. Its not been overclocked and uses the stock Intel cooler.
I decided recently that I'd like to try overclocking and ordered myself a Tuniq Tower 120 Extreme after reading a few reviews.
The cooler arrived today, but before installing it I decided to check what sort of temperature the CPU was currently producing. The screenshot below was the results obtained whilst running a Prime95 "Blend" test:
The Core0 temp flickers between 85C and -42C (I assume 85C is the max it can read?!!?)
Having done a bit of research I realise 85C is probably a lot hotter than I should be expecting.
I know there are probably quite a few reasons for this, but what do you think would be the most likely? Additionally, why would the clock speed not be going above 1600? The bios is all at default settings, past that.. I'm clueless!
Edit: forgot to mention, idle temps are around 58C
