specs of dust/dirt under iphone screen
13 Jan 2006
Wigan
just recently ive noticed several specs of dust or dirt under the screen of my iphone, is there anything i can do or do i have to just live with it?
they are annoying me as i know they are there and notice them every time i use the phone.
i should add that there are no cracks in the case, just the light scratches expected so ive no idea how anything has gotten under the screen.
If its under warranty take it to an Apple Store. It will be replaced on the spot. I had my 1st one replaced for 1 speck of dust under the screen - no questions asked, they just replaced it. :)
ok cheers for that, if i take it in and they swap it do they transfer everything over to your new phone or do i have take off my photos etc before i go?
how long is the warranty? i got mine in september so 6 months old
Before you go to the Apple store back it up with iTunes then do a factory reset. IIRC the warranty is 12 months.
I have exactly the same. They told me that it was my fault because the chrome bezel has come away from the body because of "Drop Damage" even though the gap it at the top left hand corner and the dust is coming in at the bottom left hand corner upwards at a 45 degree angle. I would suggest you really fight your case on this one, dust is incredibly annoying when watching movies and playing a game with a black screen. Good Luck
