Taking that at face value and knowing the core/shader ratio - that would put the 480SP part at between 27.7% and upto 40% faster than a stock 5870.
I'm really not bothered by the performance of these cards, I don't intend on buying a first gen GF100 and I don't give a toss if its faster or slower than the ATI 5 series.
And its not that ridiculous conclusion as its based on extrapolating known data.
EDIT: I wouldn't hold too much to that info tho hence why I said taking it at face value, as nVidia is chopping and changing things like mad atm and whats true one day might not be the next.
He has a point Rroff
This is getting tiresome, I mean isn't it a bit late to be changing such important details? So basically nvidia were misleading people all this time.![]()
Who says Nvidia are misleading people. Nvidia have said nothing officially at all. About the only things people have said come from ATI fanboys!
You don't have any known data about performance at all, you're extrapolating based on your complete guesses and no, no one else on earth believes it will be that much faster.
You keep missing some vital things when you mention things, clocks haven't been increased massively over earlier leaks, which is the ONLY info you could possibly have. You're taking the early data I assume and ASSUMING you know the clocks of those tests, even though you most certainly do not, as no one does, and upping/decreasing those numbers as you see fit based on the possible clock change.
Its most likely the benchmark results we've seen to date are on 512sp parts at circa 650Mhz clocks, meaning around a 7.5% clock speed increase, with a roughly 7.5% SP reduction...... which would lead a normal person to conclude it would likely be a bit of a wash. More than anything the less sp's and marginally higher clocks probably result in them getting a higher yield.
All along we've been told the 480gtx will be 5-10% faster than a 5870, for months, from many sources and from the most biased Nvidia sources now aswell. Yet you've decided its up to 47% faster, but at least 27.7% faster.
Rubbish.
The less SP clusters, the worse, because Fermi can only put new code through a single cluster at its smallest I believe, similar for AMD but they have more clusters. Meaning to run physx on the gpu the more clusters the better as Physx will always take at least one(or any other gpu code, open cl physics or acceleration of anything).
Consider we're still in the situation where a £200 5850 can likely overclock beyond any overclocked performance the 480gtx can give, which will cost over twice as much with zero supply, and a 470gtx is set to cost £300, so 50% more for 5% more performance and far less performance with both overclocked.
Thats of course assuming the clocks/sp's are really confirmed, as others have confirmed in person, AMD and Nvidia like to leak almost accurate, but slightly incorrect information as a way to track down leaks. But again I'll point out, this could easily be the spec, or even lower than what we've seen benchmarked so far. People are incorrectly reading into a sudden 10% increase in clocks out of no where, its not, its a 10% increase in clocks over what we guessed the clocks would be. You can't take existing benchmarks on UNKNOWN cards and increase the scores 10%.
If AMD came out now and said a 5870 actually has 400Mhz clocks but it lied about clock speeds, it doesn't change the performance just because your knowledge of the specs changed.
THough again I don't think final specs are what we saw benchmarked, not exactly, they were "best guess at what performance they could get", and while they are playing with clockspeed/sp combo's to get the best number of cores they can, I doubt performance will change much more than 2-3% either way.
No where reliable has said the 480 is only 10% faster. More likely, based on earlier reliable rumours is the 470 is 10% faster than a 5870 and the 480 competes better with the 5970 although loosing. Thats what we got after A2 silicon benchmarks.
