You stated that for a right angle triangle, my definition of height wouldn't work out. So I drew a right angle triangle for you.
Subdividing it into two was the "proof" that half long side times "jon's height" gives the area, as "1/2 base times height" is obviously true for a right angled triangle and you didn't seem to agree. My point is that height has to be defined like this, or the equation doesn't give the area.
Would you feel better if I redrew it without the 90 degree angle, picked a side arbitrarily and then split it into two right angled triangles? Touch has pointed out that it doesn't matter which side you start from, I'm not sure if "any side times perpendicular distance to corner" is easier to remember than "long side times perpendicular distance to corner" or not. The second seems simpler to me.
