To start use CCC Auto Tune. That will give a good idea of performance at stock volts. Then play with MSI Afterburner.
thats good mate, wats the most you could push a 5850 on stock volts? what do you mean by editing the cfg file for afterburner to allow 2d and 3d settings? When i look in ccc my 5850 when im browsing drops to like 157mhz core & 300mhz memory, but just to mention i have not overclocked mine.
msi afterburner confuses me totally
i have it setup with 2 profiles one 2d one 3d, but the 2d one keeps the same voltage as the 3d one, i can never tell if its running or not unless i open it and visually check, it seems to mix the settings up.
On stock volts it went to 820 core & 1110 mem.
If you card is dropping to 157/300 then something is overclocked somewhere. I believe the normal low setting is 400/1000. Also, do you have 2 monitors.
The cfg file is to do with MSI Afterburner settings. By changing the "enable unofficial overclocking" it stops powerplay dropping the core/mem to 157/300 which if you are running 2 monitors causes flickering when upping and dropping clocks.
I have enabled 2 profiles in Afterburner, one for the 2d settings, 600/1000 at 1v and currently 850/1135 @ 1.125v. Temps for me are not an issue as its watercooled with a full cover EK block.
Being an Asus card the only program youll need to overclock it is MSI Afterburner which if you download comes with MSI Kombustor which is basically Furmark but instead of a moldy donut you get a cool blue furry MSI .
If you need any help or have more questions Ill be happy to share what ive learnt so far with this card.
a lot of people think there card is stable at high clocks and some possibly are but tests such as furmark are deceptive because if the memory is clocked 2 high you dont get artifacts or anything as the card just resends the commands. The only way to test this is to run benchmarks and compare framerates.
I have been using 3dMark vantage and I could tell on the opening Jane Nash scene if my core didnt have enough volts as the water became un natural with abnormal peaks.
Mine does.I thought these cards by default dropped to 157/300 when at idle.
I have just ordered one of these because I am finding that my northbridge is getting rather warm since installing the 5850. The H50 CPU cooler means that I don't have much air flow in that area - hopefully the Spot Cool will help.As a side note I have left my fan at stock, but have used a spotcool to hit the back of my card, mounted it in a hole drilled in my antec 300, brings air through the side vent right onto the business part of the card, I would recommend it to anyone who doesn't want to tinker with aftermarket coolers- shaves a decent chunk of temps and stops my processor heating up as much when the card starts getting hot.
Cool mate nice case! dont you find the stock fan profile to slow? when left on auto the fan never seems to go above 30%, i know the fan does get kinda loud but if you pump up the sound of your game you cant hear it and you do have cooler temps![]()
