Celebrated 5 years of PAX drivers.
“Pax PCI X-Fi All OS Creative Software Suite 2010”
- XP/Vista/Win7 – 32/64Bit - Read me
PAX
Performance Audio Xeleration
Tweaked Drivers for Creative Soundcards:
Better Performance. Better Audio. Better Xeleration.
CD is base from Creative Titanium Cd
“Tweaked Edition”
Supported cards:
Sound Blaster X-Fi XtremeGamer Fatal1ty® Professional Series
Sound Blaster X-Fi Platinum Fatal1ty Champion Series
Sound Blaster X-Fi XtremeMusic
Sound Blaster X-Fi Fatal1ty
Sound Blaster X-Fi Elite Pro
Sound Blaster X-Fi
Soundblaster X-Fi OEM Cards: Dell, HP and Gateway
Setup should work with any XFI Card now!
UHAA FULL Support now.
Supported OS:
Fully working Suite for XP, Vista, Win7
32 and 64Bit
Based on:
SBXF_PCDRV_LB_2_18_0013
Software Updated base on
XFI Surround 5.1
PAX Changes:
+ Updated tweaks
+ Fix Creative Auto Updated it does work with my drivers.
SoundFont Bank Manager 3.21.02
Creative System Information 1.10.08
Sound Blaster Vista Control Panel 1.02.01 < XFI Surround 5.1
Common Audio Driver Interface 2.30.50
Creative Audio Processing Object Interface Module 2.47.00
Creative Audio Processing Object Interface Module 1.36.01
Creative ALchemy 1.41.02
Creative On Screen Display 2.00.06
Creative Auto Tag Cleaner 5.20.00
Creative Media Toolbox 5.10.02
Volume Panel 2.21.13 < XFI Surround 5.1
Creative Vienna SoundFont Studio 2.40.55
Creative Smart Recorder 2.40.23
Creative Karaoke Player 1.60.15
THX Setup Console 3.10.08
Speaker Connection Wizard 1.00.24
Creative Diagnostics 5.11.02
Creative 3DMIDI Player 1.11.01
Creative Audio Control Panel 3.00.47< XFI Surround 5.1
Creative Audio Engine Licensing Service 1.00.01
Creative Software AutoUpdate 1.40.04 < XFI Surround 5.1
Creative Console Launcher 2.61.43
Audio Device Selection 3.01.00
http://dl.technewshw.com/drivers/Pax%20PCI%20X-Fi%20All%20OS%20Creative%20Software%20Suite%202010.7z
When people uninstall their drivers always make sure they run setup.exe in .\PAX\Audio\Drivers. Then select the uninstall option and tick the option delete all shared.
Also make sure you uninstall the software in add remove , boot into safe mode and use ccleaner & driver sweeper then reboot and install as normal.
Yes i'm using them , yes they sound brilliant. You don't have to install that software either , just select custom install when installing
PAX
“Tweaked Edition”
Supported cards:
Sound Blaster X-Fi
Supported OS:
32 and 64Bit
Based on:
XFI Surround 5.1
PAX Changes:
+ Updated tweaks
