Just thought I'd update this thread although I've not made much progress since my last post!
 . . . just have been playing about trying to get the HT Link/CPU-NB MHz running a little faster . . while using [Auto] volts for both of them of course!
The HT Link didn't like running faster than 2128MHz when combined with the higher 3724MHz CPU frequency? bit odd as it is ok running at 2500MHz when combined with a lesser 3500MHz CPU clock? . . . not a biggie and probably something I can work through by manually boosting the HT Link voltage . . . . anyway I thought I would come back to the HT Link later and have a go getting the CPU-NB boosted, changed it's multi from [x8] to [x9] and that worked fine!
Click for stability . . . 24 hour "Blend"
Oi don't laugh!
 . . . 2128 >> 2394 is an extra 12.5% CPU-NB Speed, not bad for a weeks work!
 . . . . after excessive stability tests I left the machine folding for a few days . . . PPD not as good as I hoped but I suspect I may be getting some dodgy work units? . . . either that or Folding likes level 3 cache?
At 3.7GHz the PC is plenty fast, considering the minimal effort needed in the BIOS with most settings still on [Auto] and it's "utter" stability I think few will complain! . . . . really want a GPU now to play some games and do a few game benches!
So after getting
3724/2394/2128/1064 "validated" for stability I decided to see if I could get a bit more speed from the CPU-NB . . . 2394 >> 2660 . . . this was accomplished by changing the CPU-NB multi from [x9] back to it's default [x10], I also needed to manually boost the CPU-NB voltage to 1.2500v to even get Windows loaded properly!
Prime Blend didn't last long using just 1.2500vCPU-NB so slowly but surely that got boosted all the way to 1.300v then finally
1.325vCPU-NB to get "full" Prime stability . . . however, this is when I noticed something strange . . . . the CPU-Multi started dropping to [x4] while the processor was fully Prime loaded, the vCore would also drop down? . . . basically as if CnQ was kicking in except the chip was 100% loaded across all cores . . . It's not locked at this speed but appears to drop once or twice a minute and lasts 2-3 seconds?
Processor is at full 100% load in the above image . . .
I'm still not sure what is causing this, CnQ is disabled in BIOS, I don't have CnQ drivers installed and I also tried changing the CPU multi in BIOS from [Auto] to [X14] but still no joy? . . . the "Throttling" issue goes away if I reduce the CPU-NB clock and reduce the CPU-NB voltage to reasonable levels? . . .
I thought maybe this could be a safety feature of the processor or perhaps a "limitation" of the baby uATX board I am using? . . . It seems to be down to a combination of high vCore along with a high CPU-NB voltage, I did notice the core temps increase a little bit from the added CPU-NB voltage but not seem them rise above 49°C yet so I'm not convince this is a Thermal problem? . . . . checking in SiSoftware
Sandra shows
the Propus has it's Thermal protection set at 99.5°C
Deneb 965 vs Propus 630 (Cutout) . . . thanks to gareth170 for the pointer!
My personal
Athlon™ II X3 Rana runs fine at 2.66GHz CPU-NB so I'm thinking that maybe the extra core of the *overclocked*
Athlon™ II X4 Propus is pulling a bit more power than perhaps the motherboard can accommodate, it's the "Pro" DDR2 board below:
ASUS M4A785D-M PRO
Webpage
Support CPU up to 125W
4+1 Phase Power Design
So maybe 4+1 phase is not enough to deliver a high *dual-plane* voltage to an overclocked quad-core?, I'll have to look into that but I notice some of the slightly beefier board state they have 8+2 Phase Power Design . . . hmmm
Another area I am suspecting is the PWM/Mosfet cooling . . or lack thereof!
 . . . . I opened the case and had a good nose and yes indeed the PWM/Mosfets are running "Wickedly" hot while the machine is under heavy load, couldn't hold my finger-tips to them for much over a few seconds! . . . I've got a few spare BGA heatsinks knocking around so I may slap them on the PWMs and deploy some spot cooling to see if that helps rid me of the "Hokus-Pokus!"
