Using an 8800GT at the mo. My 4870 is currently away under RMA.i think i will wait until A and B are done - i think my 5850 should be just fine
what GPU do you have?
Good game. Haven't finished it yet but think I am probably quite near the end. I have enjoyed the combat more, by the sounds of it, than some of the others...though one of the shotguns is ridiculous in that how many shells it takes to down an enemy. The gaming experience for me has been quite smooth. It ran pretty well, all considered.
Just been playing in the dark with volume up reasonably loud. Played through the Ghosts tunnel section near the start, needless to say I was staying pretty darn close to the guy who guides you through it.
Also had my biggest 'jump' moment while playing any game ever, I was hidden in the shadows and saw one of the monsters crawl past me and through the door I just came through, strange thing was it was looking at me all the time. After about 10 seconds I started moving on, crawling out of the crevice and putting my back to the door. Almost immediately it was on my back, I literally shot both barrels of my shotgun aimlessly, hit escape, and had to sit back and let my heart calm down for half a minute.
Really good game.
Anyone having probs running this, take heed. I am now running at 1920 res on DX10 with everything on HIGH with no stutters.
Here is what I found after ****ing about with this for 3 days.
Go into your system properties where you usually allocate the virtual memory. There you will find a tab called Data Execution Prevention.
Click on this and add the Metro 2033 executable to the exceptions (or turn it off completely).
The other thing is to check that it's not running in compatiblity mode if you are running Windows 7. Right click on the Metro2033 exe file and click properties. there you will find compatibility settings. Uncheck them if they are checked.
Has anyone had an error message about a missing physxloader.dll? Spent 4 hours this evening trying to get it to work with no joy. Really beginning to wish I bought this on my Xbox or not at all.
