Fractal every time. Quieter case, better cable management and more hdd space![]()
yeah, unless you put fans in, it's not that great at coolingDepends what you want to use it for. The r2 is awful for cooling unless you populate the empty fan bays with something else.
Andy
 But i seen a video on you tube and he had a i5 setup in it with a H50 and his temps were 30-40 degrees. will be getting a H50 most likely too.
I have a 300 and i dont think its great for cooling to be honest i have and i7 with the h50 and get 47deg ish
it was much better value when I bought it for about £30 a year or so ago. Mine is pretty silent (I can only hear the hdds when idle) I run stock fans on low and have some other fans controlled by my board.300 is a crappy case, even for a budget case.
All stock fans need replacing and all fan mounts populating for it to keep a 4890 at reasonable temps. And then it sounds like a wind tunnel.
There are much better cheap cases.
 R2 soon for me
