ATI overdrive on Radeon 4850.
5 Feb 2006
I'm trying to squeeze a bit more out my ATI Radeon 4850 which is running at stock speeds.
when I run the ATI overdrive feature in CCC all i get is a screen of rainbow coloured vertical stripes.
The card or PC does not lock up as I can hie esc twice and go back to the desktop etc.
I'm running the 10.3a preview drivers. I'll reload the 10.2's tonight to see if i get the same.
Is this normal for the overdrive feature or do I have card that is either faulty or not overclockable?
That's the clock testing tool..
Did you hit auto tune..?
The vertical stripes are normal. If you alt-tab back to CCC you'll see a Auto Tune dialog window and you can watch the core and memory clocks increase whilst it tests the configurations.
http://www.legitreviews.com/article/766/10/ <-- The dialog box I'm on about is the second image in this article.
I'm running it at the moment, it's been going for a fair whilst now and it's is current on 780/945 (core/memory) at 90 degrees.
