same here, it tried all three, cant get them to work, im on 02. 0743 worked fine though.
Is there a certain setting that needs to change to get this to work? I tried this and still have same issue (NO IP address assigned)
Hi,
I've recently flashed my Netgear DG834GT with 'DG834GT_V1.03.22_DGTeam_1007_eng.img'
But suffering the same problem as Dynamic IP O2 users, the line will sync and connect OK but I will not get an IP address assigned and hence no internet.
The problem is i've tried reverting back to my old release which worked (UberGT1-06-beta4.img) and now that still has same issue with NO IP assigned.
I've even tried flashing with DGTEAM version 0743 and still the same!! So I seem to be having no luck at all.
Any help would be greatly appreciated as i've lost over a day with this so far and had to use an old router as I can't seem to restore the Netgear at all.
Many thanks for any help.
Kevin
Anyone know how I can connect to my router using this new openvpn?
I've just set this up (was using ms VPN from WHS).
Config with defaults on the router VPN page.
Enable SSL support
Generate key
Save the key
On the client (mine is Win7)
Download and install openvpn-2.1.1-install.exe from
http://openvpn.net/index.php/open-source/downloads.html
This includes the GUI
Copy your openvpn.key you saved earlier into \program files\openvpn\config
Create a text file called netger.ovpn with
dev tap
proto udp
remote YOUR-IP-HERE 1194
resolv-retry infinite
nobind
persist-key
persist-tun
mute-replay-warnings
secret openvpn.key
cipher DES-EDE3-CBC
comp-lzo
verb 3
Start OpenVPN GUI in admin mode
Double click on tray icon and it should connect
# pwd
/root
# cd /new
# ls -l
-rwxr-wr-x 1 root root 3653632 2010-03-21 01:36 DG834GT_V1.03.22_DGTeam_1007_eng_adsldrv023o.img
-rwxr-xr-x 1 ftp ftp 12570 2009-05-03 09:02 nftp
-rwxr-xr-x 1 root root 5900 2010-03-21 01:37 nftp.tar.bz2
# su -c "/new/nftp -u eth0 DG834GT_V1.03.22_DGTeam_1007_eng_adsldrv023o.img"
Sending frame on eth0 (computer-MAC)
Found a router at router-MAC
Router is a DG834GT-1SKUKS
Current version is 121c
Max upgrade size is 36 kb
Could not find "magic hardware header" in this image.
Uploading this is not recommended.
anyone ave any idea where i can get 1.02.16 - DGTeam Rev. 0848, this version has really messed up my connection.
emailed it to your hotmail, and it bounced back
