Why isn't there ANY?!
20 Jun 2004
Essex
Wifi-N, dual-band adsl routers with gigabit ethernet??!! :(
The closest seems to be the Netgear DGND3300 but that only has 10/100 ports....
Are there any out there that I have somehow missed?? Any coming out soon?
DGN3500
http://www.netgear.com/Products/RoutersandGateways/WirelessNRoutersandGateways/DGN3500.aspx
Standards
IEEE 802.11n version 2.0
IEEE 802.11n, IEEE 802.11g, IEEE 802.11b 2.4 GHz
WAN (ADSL): ITU 992.1 (G.dmt) Annex A, ITU 992.2 (G.lite), ITU 992.3 ADSL2(G.dmt.bis), ITU 992.5 ADSL2+
Physical Specifications
Dimensions: 223 x 153 x 31 mm (8.8 x 6.0 x 1.2 in)
Weight: 0.5 kg (1.2 lb)
Features
Privacy & parental controls
Double firewall protection
Denial-of-service (DoS) attack prevention
Intrusion detection and prevention (IDS)
Wi-Fi Protected Access™ (WPA2-PSK, WPA-PSK) and WEP
Wi-Fi Protected Setup™ (WPS)—push-button and PIN
Push 'N' Connect using Wi-Fi Protected Setup™ (WPS) and Smart Wizard®
Exposed host (DMZ) for secure gaming
Supports Wireless Multimedia (WMM) based Quality of Service (QoS)
Warranty
Localized to country of sale
Package Contents
RangeMax™ Wireless-N Gigabit Modem Router (DGN3500)
Stand
Ethernet cable
Setup CD
ADSL phone line filter
Power adapter, localized to country of sale
Sadly OCuk dont stock it but I do know who does but cant mention it on here.
WAG320N is one, DGND3300 another, there are are more but given the choice the flexibility of cable router + separate modem is generally better.
I'm starting to think that's the only option! Was trying to avoid it though as already have about 13 plugs trailing about and less and less space to cram things!
Maybe a Netgear DGND3300 and a Netgear GS608 would do the trick... but bit annoying that the router would then be black and the gigabit switch white..... damn you Netgear!
