I would have hoped you would have been more forgiving aswell , instead of just kicking, as if inbalance isnt on all servers, as soon as i could i would have switched, the first time i tried i even went running up the road to the enemy team so i would die.
There's some bloody dodgy sniping going on :/
How the hell I can be one-shotted by a sniper when I'm travelling at full speed on a jetski or quadbike? Fair enough, you get the odd lucky shot, but it happens regularly. B*stards.
Think they went down around 2230, as that's when I joined and noticed nearly every server was near empty (which at this time is rare).
What's the default key for parachute? Jumped out of an ailing chopper...and became a 2D mess on the floor!
Not always , depends on whether they are a fair distance away. If so , it helps to right click to get that tiny bit more accuracy.
But if it's close quarters I wouldn't tend to right click , no.
Sniping qiuiestion....the game includes bullet drop...which means if you aim from a large distance you need to aim above the head accordingly. Now...what about horizintal movement. If you are aiming from distance at a target that is running acrosss the screen...from right to left say....do you need to take into account the horixontal moveemnts of the opponent also..aswell as allowing for bullet drop????
i.e...for someone running across the screen at distance from right to left you should be aiming and firing 1-2mm to the lft of his head and also 1-2mm above his head for bullt drop...so your target position is effectively North West from centre of head for headshot.
Do you have problems with shotgun hit registry at all? Other day I was standing about 5 yards behind an enemy just out of knife range, cursor aimed square between their shoulders then were crouched, totally still and facing the other way. 2 shots pumped into their back, neither registered, a further in their head, again didn't register. At this point he turned round and popped 1 M1911 round into my head. Sigh.
The Shotgun is really bad, I have no clue how people get stars with them. Yet im killed a lot by them. Lucky if I get a kill or 2. lol
Anyone bettered 304 points from a markman sniper shot, got it the other day with the m95, the shot took a good second to reach my tarket and the mavity dip was judged from 2 previous attempts.![]()
Yeah I get that, mostly on that level where you have to start assaulting the base by heading down an long road.also does anyone else, at really long ranges, see stones and doors etc disapear? i do! i think i can hit someone, then it looks like ive missed . suddenly realise that the guys are probably hiding behind a rock... run up and yep they are!
It was a mistake, and a very easy one at that. If you ever have to admin a server, and endure the alt-tab fun, you'll understand that it wasn't malicious. I'm amazed I haven't managed to kick myself yet.
That's quite a long way, best I've had was a 242 which was from the "sniper hill" of the first part of the map where you first have to assault a small island then move into a town area, took the shot from that hill all the way over to a Recon next to the B point in the town area. Bullet took about 1.5 - 2.0 seconds to reach him. Dip offset was about 2cm.
