Hi there
please could you tell me which motherboard would be the fastest/cheapest and there main differences 780-795 chipsets ect
not really interested in SLI/CROSSFIRE
It would help if you specified either:
a) that you want the cheapest that will run well
b) that you want the best regardless of cost
c) that you have a budget of £xyz
Rule of thumb, cheapest is not the best, and the best isn't cheap, so people need to know what your cash limits and expectations are before they can recommend much
But as a starter, I've been running an Asus M4A79XTD for a couple of months, and am generally please with it. Runs my 955 BE at a lovely overclock, suffers only minimal vdroop at load, and when I'm not tweaking it, is very stable and solid.
it needs to be stable as hell
not the best regardless of cost as i dont need a few things listed below
around £100 i guess
FULL SIZE ATX
and be able to fit a 9600GT in it , or larger graphics card when i upgrade
needs loads of sata connections
not bothered about a multi graphics card setup SLI/CROSSFIRE
just wondered what the difference in the chipsets is as i have seen the
ASUS M4A785TD
ASRock M3A790GXH
ect and assume the 790 is the latest ?
i understand AM2 is ddr2 and AM3 is DDR3
any insight and help will be very much appreciated
please forgive as i have been out of this building lark for a while
cheers !
890 is the latest, but USB 3.0 isn't the mainstream standard atm and there are better 700 series mobo's right now, but if everything's gonna be dedicated then get an 890.
I recently built a system based on that MB. It might not be the latest chipset, but it ain`t arf a nice board. I particularly liked the glowing logo on the heatsink, and the bios settings are geek heaven.
