Cup of tea + dell laptop
8 Feb 2006
So my sister decided it was a good idea to drink tea while browsing ebay, one fumble later and the laptop no worky.
I told her to leave it to dry for a few days and power it on.
What's the chance of ressurection?
Disassemble as much as possible, leave to dry in a warm, dry place for a few days to a week (sometimes more depending on where it's got to). Make sure you leave it upside down, or the opposite direction to the entry of the liquid. Take the battery out straight away. If the hard drive isn't wet at this stage, take this opportunity to plug it into a PC and back it up.
Once dry, see if you can find where it got to inside if you don't know already, and use some isopropyl alcohol to clean off any residues on PCBs and connectors etc. Once it's all dry, plug it in and try turning it on. Any signs of trouble, take it to an expert to see if it can be completely diagnosed and fixed should it be financially sensible.
Open it right up and clean all affected parts with IsoPropanol (sp?) (TIM cleaner works to) As any hint of sugar in the tea will FUBAR the mainboard.
Sugar??!! Are you sure? AFAIK its an insulator.... Seems unlikely to be a killer to me but I have absolutely no direct knowledge - just suprised.
if its dead you can sell the hard drive (Assueming its not also wet) / power adapter on ebay, and also sell the laptop as faulty / water dammage as someone may want the screen...
meths can leave a residue on the board tho.
worth stripping down as there MAY be a fluids tray that caught most of it.
or it could have a big ass short across the motherboard and it be DEAD.
check for burn marks.
