My Powercolor 5770 arrived yesterday from OcUK. In the box was the card, cd and instruction sheet.
The card I have has a clear fan, however ones in reviews have a full black cover over all the card and red fan...
I read this on a site, which mine does not have. Have I been sold the wrong version, updated version or downgraded version?
"Inside the package you are going to find not only the HD5770 but also an installation manual that will help you install the video card if you are unfamiliar with the installation process. PowerColor has also packaged a driver CD with the card to make your life a little easier so that you are not looking all over the place and waiting for the download to finish up, but instead you can start using your new card right away. There is a CrossfireX bridge included as well as a DVI to Analog dongle to hook up your analog monitors to the card."
