Any men here use hair straighteners?
28 Dec 2007
Sheffield
Looking for a new pair of straighteners as the ones I use at the moment are a bit too wide and hard to use, what others would people recommend for <£40 ?
*Awaits the torrent of "gay"* :D
Yes - GHD's only ones i recommend would struggle get them for under 40 unless 2nd hand. And i use mine every DAY :) why because i have would never be able to style it without them.
My hair curls outwards on the left side of my head after drying for some stupidly unknown reason so I use a cheap little pair I bought in Birthdays(iirc) for that reason alone. Pretty decent little set.
yea I've heard a lot of people bang on about GHD's before, but unless I'm mistaken they are around the £100 mark. And 2nd hand market is apparently flooded with fakes?
What did gays do before straighteners were invented.
Slam your head onto an ironing board and use the iron to sort out your curly gay hair, you great fat gay you.:D
The gayness in this gay thread is simply extraordinary.
Gay :p Also, Remmingtons are really good, think mine cost ~£20, not sure if they work as well on man hair though.
I wouldn't bother with GHDs, not worth the price tag. But then I only straighten my hair once in a blue moon as it's pretty much poker straight anyway.
