- 15 Jun 2009
I've put Speedfan in the startup folder so it controls the fans speed, However it always loads up twice. Any solution? Running windows Vista btw.
Problem not solved. Deleted the one from startup, Removed both from MSCONFIG and confirmed that they weren't starting.They're in startup tab twice because one is the startup folder one. Delete both entries, (delete the satrtup folder one) and then copy the Speedfan shortcut back into the startup folder in the start menu.
Problem solved.
Bingo!Ah vista,.
You could try manually going to the locations:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
and
C:\Users\Your Name\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
I'd manually create a shortcut to the first location and retest then move it to the 2nd location to see which one solves the problem.
