biostar tpower x58
18 Mar 2010
hi there i have the above motherboard and i want to overclock the i7 i bought it overclocked but somehow i went back to default i might have been my fault can you tell me the setting to do that in the bios please
if this doesnt work, you can write down the bios settings and i will post up some settings to try
might be best to put the rest of your spec down so we can check it out
I've got a webnote in about the exact same problem currently.
I have thus far been completely unable to find the profiles section of the BIOS too :o
