If that's the case it could be quite dangerous??
No UPS in normal mode will trickle charge the battery , the mains is passed to the output.
When the mains fails the battery and invertor are switched in and mains is switched out , keeping your device powered .... for a while
you don't need to worry about it, UPS's are not dangerous unless you drop 'em off a building![]()
Or dont lift with your knees
To the OP: Most decent UPS have some sort of surge protection built into them. I keep meaning to look into one as my dad has been wanting one for ages for his servers.
Apparently my belkin 1200va UPS can handle 39,000,000 watts...
UPS batteries can fail/leak. We had a power cut, and as such the UPS's kicked in, 10 minutes later power was back on etc. Down in our call centre people started reporting a weird smell, and it turned out the UPS was leaking a shed load of battery fluid, and fumes were being sucked in through the air con.
It had only been serviced/checked over etc about 2 months before.....
But still I have my ups plugged in to a surge protector...
I have a few APC UPSs and then recommend that the UPS should not be pluged into a surge protector, but directly into the mains power socket...you might want to check your Belkin documentation to see if it gives any info on this for your particular UPS...
APC UPS the battery is in a easily accessible compartment & its a quick swap though not had to replace the mine in my 4-year old unit.
Those numbers are near zero protection. 420 joules means it really is only 140 joules; never more than 280. Meanwhile surges large enough to cause damage are hundreds of thousands of joules.Apparently my belkin 1200va UPS can handle 39,000,000 watts, the spec is "420 Joules, Maximum Surge / Spike - 6,500 Amps / 6000 Volts" so if you x the amp by the volts, you get how meny watts it can handle.
