Is it possible to link 2 sites with one sig?
Caporegime
1 Nov 2003
Lisbon, Portugal
Evening gents/ladies/new overlords,
Simple question, is it possible to set it up so when you click my sig it goes to 2 websites?
Currently goes to mine but wondered if a 2nd could be added? :)
Ta!
Jake
A bit of googling later, and I have found this:
http://linkbun.ch/
Put in all the links you want, then bunch them together, and copy the address for "open entire bunch". That link will open several URL's when clicked :)
(it'll also open a tab with the linkbunch site in, but hey, it's a solution)
Just tested that site, and it seems that you can't use a direct link to open every URL. It only links to the "bunch".
Another site called MultiURL also does a similar thing (you can also have random links), or like RobH says, you could do it with a script of your own.
