Aprilia RSV owners please.
13 Jan 2004
Leicestershire
hi y'all, i've got a quick question. it's a thing that any pre-2001 Aprilia RSV owners could do for me.
what size are your brake discs- the outer diameter across the disc, and the inner diameter of the gold inner bit and the inside of that.
just after a quick thing as i think i have some aprilia rsv pre-2001 discs but not sure. :confused:
i *think* i've got a spare set for the CBR and they are min thickness of 3.5mm whereas these are 4mm min thickness.
Couldn't find a tape outside so couldn't get diameter but I used a vernier and front and rear discs were both 5mm thick, if that's of use.
If Draeger doesn't get round to it I can grab a tape and measure diameter tomorrow. My bike's exactly the same as his.
any further offers?
or is there a part number i can refer to on it?
it has the brembo emblem on it and i *think* they may be warped already and apparently i met the owner in a pub/services car park and got them for nought lol.
so er..... :D
to measure whether they're warped i just put them on a flat surface such as glass and prod each bobbin after putting the down disc side up? it shouldn't move at all and if they are warped it will move a mm or so? :confused:
