- 8 Mar 2006
- Telemark
Fuel problems are usually more intermittent. :\
I've been told that if a O2 sensor is shown to be at fault, that it could be another fault that is triggering it? Is that true?
One step at a time, shelve that thought.
Also, I love the way your thread on uk-mkivs.net has turned into an argument about the top speed of the car, and if you really need to rev that high anyway. What a bunch of tards.
My guess is the Lambda/oxygen sensor on the catalyst.
The AKL 1.6 has a single coil with HT leads.
Yes, pretty much.This means that my missing power issue is intermittent, and is not related to the air intake.
Not particularly, but I don't think it's a fuel related thing anyway.Also, this rules out any fuel line related issue doesn't it?
