CLOCKS FORWARD THIS SUNDAY !!
I was working at 2am, I did the same amount of work (As I do the same amount of work everyday, and it takes as long as it take), It just seemed like it took an hour longer (Which sucked) and I just got in an hour later than normal :(
ah, I understand, that is a bit rubbish. I am glad I work by the hour in this instance although considering the amount of work I did I wouldn't have gon at all if that were the case. :D
Oddly my Xbox360 clock refuses to change even though I've got it set to use daylight saving.
I'm connected to Live and I've also manualy set the clock an hour forward but as soon as I reconnect to live it goes back an hour. how norty !!!!
If we all ganged up and refused to change our clocks we'd make a difference. Are you with me brothers?
DOWN WITH DST
Lunch time now.
