I've just got my shiny new WC set up so I thought I'd post some pics and stuff.
For those interested, my spec is in sig, and here's a list of WC parts:
it all adds up
I went for a 'sealed' system in the end, despite many places advising to the contrary
I'll see how it holds up before deciding if it was the right choice.
Pics:
First, the leak testing. Copious amounts of tissues, I had a bit of a problem with the join at the PCI bracket. In future I probably wouldn't bother with that, I'd just use the rubber grommets preinstalled in the case - the main reason I went with them was to ensure the inside tubing was seperate from the outside tubing so the inside stuff couldn't get yanked. I also had to mod my case with a pair of pliers and a hammer to persuade it to fit properly into its slot.
Next, the tubing all set up inside the case, one with a graphics card/PERC 5/i fan and one without.
Finally, a pic of my very dusty H50, used for ~4 months without a dust filter. Thought my temps were slowly getting hotter but attributed it to warmer weather
Currently my OCing efforts have resulted in a still-stabilising
() 4.45GHz, currently at 1.5Vcore which I don't want to take any higher, with temperatures peaking in the mid-80s on IBT (note I currently only have one of three fans installed with shroud; the other two are currently just resting not-so-tightly against their positions on the radiator while I wait for a couple more shrouds (120mm fans with hub missing) to arrive) which I'm not too worried about. Dust filters are also a possibility but I haven't really got any plans at the moment, they seem too expensive to be worth the hassle.
- Swiftech Apogee XT CPU block - £55.57
- XSPC RX360 radiator with 3xSan Ace fans - £55.50
- MIPS Fusion NB block - £13
- Laing D5 Vario with EK Xtop Rev 2 - £48
- 3m 7/16" clear tubing
- G1/4 compression fittings throughout
it all adds up
Pics:
though I am now on the lookout for a sub-£150 940!
As a result, I got upset and forgot to install it anywhere so it's just kicking around outside
hehe.
