- 27 Apr 2004
- In bed with your sister
They're on their way. Released today.
Bit-Tech have done a gaming review on them and the news isn't brilliant. Only marginal gains on the HD5870m for a lot more money and a lot more wattage for the most part. Ahead of the 5870 in some tests but behind in others - it even got it's arse handed to it by the GTX295 in a couple of games.
LegitReviews managed to get samples of the new GPU3 core to test it (it won't work with GPU2). It scored up to 70% higher than a GTX285 but uses 100W more power and runs a damn sight hotter. It also uses nearly three times as much CPU to run it.
All in all, I think I'm better off with my GTX295 - more points for less watts and less CPU used. Hopefully there will be a load of 295s to be had cheap once these finally hit the shelves.
Apparently the new GPU3 cores will be out sometime in April and will work with these 4** and the 2** cards but nothing else at the moment, according to the LegitReviews article.
If these reviews are accurate, Nvidia have dropped the ball somewhat.
