I just called the local Ford Dealership.
The Service team confirmed that Batteries are only covered for the 1st year.
However, if you buy a new Ford Battery - That comes with a 3 year warranty??
What a load of 'YOU KNOW WHAT!'
Literally anything is covered if you know how to moan enough![]()
How old/many miles was it on when it broke?how should one go about moaning in order to get a new gearbox put in a CLS?
Phone and complain that you think this is unreasonable and not what you expect when you purchase a brand new car. Why do the batteries bought from Ford come with a 3 year warranty, yet the one with the car only 1 year? Do they fit sub-standard b-grade items to new cars so that you have to buy one sooner? If not, then you expect the same warranty.I just called the local Ford Dealership.
How much is the repair/replacement cost?
Probably not. You'd have to be pretty abusive to break an automatic transmission. It's the sort of the abuse it just won't be able to record very well (like dropping from N to D at 7000rpm, or winding the torque converter up).And can it be shown that you were being a **** with it?
Has your dad had it since new? Do you know for sure if they have always been like that? Go to a MB dealer (not your usual one) and blag a test drive in a CLS, check how the transmission changes down. Write to MBUK, as you have indicated you are, and just stress the absolutely dismay you feel about the service you have received. You can't believe that after 25 years of driving MB cars that this is what it is now about etc. etc.!07 car, 30k miles, not broken, but down changes are not smooth. the dealer's answer was "theyre all like that" and then took my dad out for a drive in an 08 car that was 10 times worse.
ive told my old man to write to MBUK to put the case to them and how the dealer effectively drags the (already naff) mercedes reputation through the mud when they say theyre all like that, effectively saying after all these decades MB cant do auto gearboxes
