I downloaded a torrent last night that was supposed to be an xvid of a tv show i used to watch and after extracting the resulting file was a single .rar file an not an avi as i had expected which immediately set my spidey senses tingling.
I tried to scan it with MS Security Essentials but for some reason it wouldn't complete the scan. I scanned it with malware bytes which i reported it as clean so i decided to open the archive (not extract) to see what was inside. The file inside deadwood.avi.exe so instantly knew it was a poor attempt at hiding a virus so i deleted everything.
About 20 seconds later Security Essentials popped up warning me about three risks, all trojans, from the file i just deleted. I clicked 'clean computer' and it reported it as a success.
I'm basically very paranoid when it comes to security which is why i wanted to ask on here if I can safely assume that everything is now OK or if i should perform further checks/tests or just go ahead to reformat to be on the safe side. I would tell you what those trojans were called but for some reason Security Essentials hasn't logged the history.
Thanks.
Thanks.
