Ummm.. one or two of you are saying Ups are basically useless
UPS does only what it claims to do in specs. It provides temporary power during blackouts and extreme brownouts.
Now add some near-zero protector parts. That means sales brochures can hype 100% surge protection. Does it provide effective surge protection? No. It only provides near zero protection. But the majority will now hype it as a surge protector. Same process proved Saddam had WMDs.
For over 100 years, surge protectors made even direct lightning strikes irrelevant. But no protector is protection. Those protectors worked because of a short (ie 'less than 3 meter') connection to what provided protection.
Why are companies such as Monster also in the surge protector business? Hype a protector without earth ground, then claim surge protection in sales brochures. No claims for protection in their numeric specs. But a majority will again preach the myth.
What exactly do you want to solve? Which power anomaly? Most forget to start with that question. Then consult salesman as if experts.
Effective surge protection for any home costs about £1 per protected appliance. But an overwhelming majority do not learn this. Sales propaganda is, unfortunately, the only information source for a majority of consumers.
Typical UPS connects your appliance directly to AC mains when not in battery backup mode. If voltage drops so low that incandescent bulbs would dim to maybe 65% intensity, then a relay switches over to ‘dirty’ power from a battery.
UPS circuits are so simplistic that a replacement battery may costs as much as the entire UPS. Circuits so simple that, for example, if you power a second UPS from a first UPS (in battery backup mode), then the second UPS will see no power. Instead switch to its battery. Same reason why a UPS may not recharge its battery from less well designed generators. A UPS does not monitor power. A typical UPS does everything as cheap and simple as possible. So simple as to easily be confused by anythng but ideal sine waves.
So what anomaly do you want to solve? That is where an answer begins.
