I may be starting an MSc in the autumn and was generally looking around at various bits and pieces, such as employment rates, and it just seems now that MSc's are becoming what BSc's were 30 years ago. Everyone now has a degree (essentially) and a degree now doesn't mean jack, yet a Masters only means a bit more and will still not "guarantee" you a job.
Now considering you used to be able to go to university at a heavily subsidised rate (grants etc) and BSc's were quite rare and well thought of, we are now starting to get into a situation where you will need to not only pay the £20-30k for an undergrad degree but also the £20k for a MSc before you're likely to get a decent graduate job. That is a massive debt for someone starting their "Adult" life (considering only £15k of that will be a student loan) if they aren't fortunate enough to get a scholarship for either course, especially as the number of masters graduates are becoming greater and greater every year, with scholarships being pressed even more.
We really need to sort this out some way or another as it's starting to get ridiculous, the number of job adverts now that won't even consider you without a masters is rising, which means even those with excellent extra curriculars will be hard pressed to get a decent job with just a BSc, and in the near future I can see even the really popular grad schemes starting to specify a masters minimum (technical areas in a lot of oil companies, eg. BP and Shell already do).
