Hi Aedus,Not that I doubt you, but are you sure those fans are pointing the right direction? Because from the pictures they look like they're facing the wrong way.
Looking at this picture:![]()
It looks like the side with the sticker (The 1 pointing into your case) is the side which is blowing air in.
and from this picture: http://www.techpowerup.com/img/09-10-28/104b.jpg
It looks exactly the same as what I thought, with the picture side blowing air out the back the opposite side from the RAM modules.
I see what you mean. In the link you posted the label on the fan is facing towards the I/O Panel. I was wondering that myself. However, the arrows on the fans are pointing towards the rear of the case and I can also feel warn air exiting. I had some doubts, but I feel it's correctly set up.
I've tried facing the fans in the opposite direction and the temps are even higher!
