I love my crossfired 4890's and its really hard to find reasons to upgrade, but last night was playing Just Cause 2 and was flyig around in a plane. The sound coming from the PC was more realistic than the sound coming from the speakers
I have considered water cooling, but to be honest it scares the crap out of me as I am the sort of person that would have bad luck and end up wrecking my system Also seems an expensive thing to do for just 2 cards
So the options are
5970 - The ideal card but over budget, really cant go over £500
GTX480 - Its in budget, and best single gpu on the market. Downside is the noise, trying to avoid that. My case temp is low though so even though its considered loud it cant be louder than my 4890's at the moment and it wont run hotter. Yeah its a power hog but then two 4890's are worse. I like the idea of 3D but also like the idea of eyefinity and the nvidia version needs sli? Which if thats the case will rule the card out.
HD5870 - The likely favorite, does everything I want
Crossfire HD5850's - Looks to offer the best performance for the money. The downside though is crossfire. My case is an Antec 1200, cpu (i7 OC to 4ghz) will sit at 50c on load, case temp will be 44c, this is with all fans set to minumum so its nice and quit. My bottom 4890 will sit at 70c with full load so thats nice and quiet, top one well thats running at over 110c with the fan screaming at 100% (it could very well go higher than that, 110 is the chicken point for me ). If I turn all the cases fans onto max the card will sit between 95c and 102c but as well as having the gpu fan at 100% there is lots of noise from the case fans as well. My concern is going the crossfire route is going to give me increased performance but still going to have the same problem with heat and noise. Which is pushing me towards the single card solution.
So with the nvidia option ruled out its down to a 5870 or 2 5850's, performance wise the 5850 wins but am I going to be doomed to the same problem I am trying to avoid?
 Also seems an expensive thing to do for just 2 cardsSo the options are
). If I turn all the cases fans onto max the card will sit between 95c and 102c but as well as having the gpu fan at 100% there is lots of noise from the case fans as well. My concern is going the crossfire route is going to give me increased performance but still going to have the same problem with heat and noise. Which is pushing me towards the single card solution.So with the nvidia option ruled out its down to a 5870 or 2 5850's, performance wise the 5850 wins but am I going to be doomed to the same problem I am trying to avoid?
