Hi
Does anyone know whether i`ll have any problems fitting this board with even a big cooler such as the Noctua NH-D14 in a Coolermaster RC-1100 Cosmos S case???
Note: I don`t need to worry about the side panel fan on this case causing problems with big coolers as i've already taking care of that.
Thanks for resonding.
Hello,
Helios, what brand and kind of RAM were you using ?
Did you manage using module with heat dissipator such as Ripjaws, Trident or Corsair Dominator with the NH-D14 ?
The NH-D14 is normally on top of the RAM slots and as I am building the same configuration i am wondering which kind of RAM i'll be able to use (noctua website has specified some of them as not compatible)...
And one last question, I also have a Xonar Essence STX (PCI Express). Is this possible to plug the card into the last PCIEx16 of the motherboard without loosing performance for the graphic card ? Seeing your picture, I think you are using the PCI version of the Xonar...
Thanks
I'm using the OCZ Platinum ram which don't have the tall heat spreaders. I don't think the others will be able to fit under the Noctua unless you raise the front fan. The NH-D14 will come with the 120mm at the fron and that has a bit more clearance than the 140mm fan. As you mentioned, Noctua's site would be best to check compatibility.
You should be able to use the last PCIe slot for a sound card no problem. It shoudn't impact on performance at all.
VK Said early april.
like the 11th-16th..
any later and I'm gonna be dissapointed.
Helios do you think Mushkin Redline, R3E and the Noctua D14 would all fit together? I know the Mushkin Redline is compatible on Noctuas site, but I wonder if anything will be different on the R3E Since the socket looks closer to the DIMMs
Hi Helios1234
I take it the Noctua NH-D14 CPU Cooler is better than both the Prolimatech Mega Shadow and Thermalright Venomous X CPU Cooler???
I was also wondering how loud is the Noctua??? and what would be the best fans to put on it for best cooling??? and have i read correctly that the only thing I have to investigate is what kind of memory i`m putting in my system before thinking of buying a Noctua NH-D14 because the this cooler goes over the ram slots and therefore it might not fit if the memory has a large heat spreader???
Thanks for responding.
Thanks for the feedback, is this possible to have a picture from the side.
I have 6 modules of DDR3 and i would like to make sure that both rad and fan will not make any problem. As you have said i can raise the fan but i don't know if the rad itself will make problem with the first DDR slot...
Anyway looking forward for your full review of the board
They should work if Noctua says so on their site. The height of the front 120mm can be adjusted to give more clearance. Do you have any links to the RAM? The distance between the CPU socket to the ram slots is no different to other boards.
http://www.vortez.co.uk/contentteller/articles_pages/noctua_nh_d14_cpu_cooler_review,6.html
It still covers the same 4 dimm slots on the R3E as it does on the Biostar.
Have a look below for the performance of all three coolers.
http://www.vortez.co.uk/contentteller/articles_pages/thermalrigh_venomous_x_cpu_cooler_review,9.html
If you get the Noctua, then don't worry about changing the fans because they are already very efficient and very quiet. At the moment, I can hear my laptop more clearly than the computer and that's with the side panel off. The Thermalright is definitely a good alternative though but might end up more expensive when you factor in the cost of the fans. The only compatibility issue would be with the ram slot closest to the CPU socket.
What RAM are you using? The radiator shouldn't be covering the RAM but I'll have a proper look for you.
 ). Noctua says it is compatible...
 ). Noctua says it is compatible...I was going to get the Patriot Viper RAM that was on special but it wouldn't have fit with the NH-D14 due to the tall heat spreaders (thanks to Helios1234 for letting me know!). I also notice that the G.Skill Trident RAM isn't compatible either. The Corsair Dominator RAM is compatible only if you remove the upper section of the heat spreaders.
Below is the compatibility list for those interested:
Noctua NH-D14 RAM Compatibility List - DDR3
	yeah shame on the price, expect loads of ud5 in the MM for £150 soon which means still have to find £200....tad to much for me
