BK/Dog is 13,200 by the wayMy calculations are based on double CP (from the Growth Egg divide CP by 2 if you don't have it.
Doesn't make that much difference I guess though.BK/Dog is 13,200 by the wayMy calculations are based on double CP (from the Growth Egg divide CP by 2 if you don't have it.
Doesn't make that much difference I guess though.Per hour, I think the King Behmoth and Bog Dog have the best amount of Gil per battle, in the whole game
Corrected, taBK/Dog is 13,200 by the wayDoesn't make that much difference I guess though.
Yes, I meant best CP is Behmoth and Dog, best Gil is Mission 24.Am I missing something RP? How do you get any gil at all from the Behemoth King fight?
Edit: Oh nevermind I think you put gil instead of CP
I have never even found a 7th tier, doesn't it go from the 6th tier to the top?
As for Gil, I have just calculated I need >16 million gil to max out 6 weapons, with 6k per 15 sec. that would take >11 hoursno way I have the patience to do the same mission for 11 hours
Not to mention the Dark Matters and other stones needed for accessory upgrading.
There is a way of turning 1 Trapezohedron into 3 according to gamefaqs guide. You need to fully upgrade one of Vanilles weapons (Mistilteinn) and then dismantle it. You supposedly get 3 Trapezohedrons and a bunch of Starblossom seeds. I haven't tried it myself yet as I don't have a spare 1.5m Gil![]()
Good tips regarding traps, especially the one with a Genji Glove.It does work, although I did it with a Kain's Lance (Fang's weapon).
Dismantling Kain's Lance got me 3 Traps which I used to upgrade 3 weapons.
I used the Connoisseur's catalog on Adamntortoise's to get 2 more Traps.
I dismantled one of my Genji Gloves (fully upgraded) to get 1 Trap.
You get 3 Gloves through the missions, so you can sacrifice one or two of those as very few scenarios/enemies need you to do over 999,999 damge per hit imo.
Edit: All this farming talk is making me want to pick up my game and start farming again, even though I got all weapons/accessories/roles completed!!
rp2000
And the fact you are itching to go farming just for the fun creeps me out, lol
You can get a Trapezohedron from dismantaling a Genji Glove? screw killing the Adamantoise in chapter 12 over and over again.
It has to be upgraded to "Star" level, but I think it only has 1 level so is quite cheap. Without upgrade you get a "Tear of Woe" (I think), Upgraded you get a "Tear of Woe" and a "Trapezohedron".
Bear in mind you get exactly 3 Genji Gloves and they cannot be bought/dismantled from shops/items.
rp2000
I got the battle time down to ~10 seconds each and 15 seconds walking, this is with Light/Fanf/Hope in COM/COM/RAV with level 8 Crystarium and tier 2 weapons.
I have just loaded up and found the area you queried (Mah'habara - Dusktide Grotto, near the exit to Mah'habara).
3 Cryohedrons = 7140CP
then
3 Rust Puddings + 1 Cryohedron = 11200 CP
The whole process takes 70 seconds (including screens and running times), so 50ish battles per hour.
50 * 18340 = 917,000 CP per hour.
(This is using Rav/Rav/Rav, with Sprint shoes on, and Growth Egg)
Edit: Com/Com/Rav or Com/Com/Com knocks this down 60 seconds per run so 1,100,400 per hour.
Edit2: This is all done using maxed out Level 5 roles, and non upgraded Level 1 weapons.
rp2000
Anyone got any tips for getting the Adamantoise down in one stagger? I get the legs down, no buffs, no shrouds, no death spell, no summons before he can quake. When he's down, I switch to SAB/SAB/SYN (Fang/Vanille/Hope) to get haste up and deshell/deprotect/imperil on him, then into COM/RAV/RAV to stagger then batter away, but he's back up with about 40% of his health left, and a Highwind as he's getting up won't finish him. Not sure what else I can try.
My guys have their 3 main roles maxed at role level 5, and one other role nearly maxed. Hope has about 2.4k Magic, Vanille about 2k magic, Fang about 2.9k Strength. Just seems not possible for me at the moment without using a shroud first.
I was originally using Fang/Light/Hope, but you seem to take more damage when you are closer to the feet and Lightning kept running in, and she's a worse healer and her and Hope couldn't seem to get the health of everyone back quickly enough.Also Vanille and Hope together is a waste. I find COM (attack) roles can do much more damage than any magic spells, once stagger is on. I suggest using 2 Coms in your team so you can Com/COM/Rav him (with enfire applied) when the stagger kicks in. Highwind can do over 1 million damage at the end, assuming you have the Genji glove on.
I was originally using Fang/Light/Hope, but the you seem to take more damage when you are closer to the feet and Lightning kept running in, and she's a worse healer and her and Hope couldn't seem to get the health of everyone back quickly enough.
so who are the main bad guys in this game? if FFX had Sin and Seymore. who does this game have and what are they like? keep passing this game on the shelvs in the shops and it just makes me wanna buy an xbox360. haha
Cheers matey, will try out your suggestions. Trying to get to the point where I can farm them without having using shrouds or summons.
Tip. I was going through the Datalog and there is actually 3 types of "Oretoises" (1 baby, 2 big guys, of which one is easier to beat than the other):
Adamanchelid
956,520HP , Stagger: 450% , Chain Resistance: 25
Common: Gold Dust
Rare: Scarletite
Adamantortoise (has 2 legs to kill as well)
3,699,000HP , Stagger: 250% , Chain Resistance: 100
Common: Platinum Ingot
Rare: Trapezohedron
Adamantoise (has 2 legs to kill as well)
5,343,000HP , Stagger: 500% , Chain Resistance: 100
Rare: Trapezohedron
As you can see the bottom 2 guys are the same apart from Stagger and HP so the "Tortoise" is easier to kill, to potentially drop the same items.
Visually they are slightly different, although this took me a while to notice. The "Toise" Has spikes on his shell and back, the "Tor" doesn't.
I found 2 "Toise" and 3 "Chelids" are in a sort of small valley at the north of the plains, all 5 stationary. Farmed them and got my 1st Trapezohedron and a few Ingots.
Hope this helps the "farmers"
rp2000
