It didn't overheat on LN2 - it was showing artifacts typical of overheating
That is akin to your "nvidia didn't lock ATi hardware OUT of Batman AA, they locked nVidia hardware IN". VERY little difference unless you want to argue the semantics until you're breathless.
infact it was probably power leakage - IMO dropping the voltage down a notch would have probably given just as good if not better clocks without the leakage issue.
In your opinion, yes, however there's nothing wrong with calling it on what it APPEARS to be until it's proven otherwise.
As for dropping the voltage, do you honestly mean to say that these hardcore overclockers have literally hamfistedly set the numbers on the cards really high and just benched it?
Come off it Rroff, you should know better than that.
They will have been tweaking the settings and messing about with different combinations of settings.
Or do you think you've got some pool of knowledge that these hardcore overclockers don't?
If you think they should have eased off the voltage and went for an all out clockspeed, why didn't they know that? Assuming it's correct?
In addition to that, what's to say that they didn't only up the v-core to allow a higher clockspeed?
That's generally how it works, no? Try the highest frequency on a specific voltage until it doesn't work properly?
How do you propose that, when they've ran out of headroom at a particular voltage, they then LOWER the voltage, to get a higher clock speed?
