Walked into my bathroom on the way to bed last night, and toed a small puddle on the floor under the radiator. "Hmmm" thunk I, "I'd better isolate that". So I turned off the radiator stop valve. As soon as I did that- PSSSSCCHHHH! Big jet of water springs out the back of it, bounces off the wall and into my face. Tried screwing in the lockshield valve, but teh plastic cover instantly fell apart, so I then tried screwing the pin in with grips, but the head of the pin sheared off. Lastly I tried screwing down the remaining shank of the lockshield, no joy- it's definitely seated but the water kept on coming.
Panick ensued, and rather than tackling the leak like I should have done, I fought my way up through the loft to turn off the header tank. Meanwhile the water is leaking through my kitchen ceiling. Eventually managed to cover the leak using an old pencil eraser wedged with a block of wood.
Nice of the heating to decide to do this the day before snow is forecast for Guildford.
Anyway, being an old-ish house, I can't find a radiator to fit the space, and I don't have the plumbing skills to move or change the copper feed pipes. So my question is, if I get a similar sized radiator from B&Q, can I graft plastic speedfit connectors and hoses onto my copper fittings, giving me a bit more flexibility (literally) in positioning? I know it'll probably look rubbish, but at least I'll be able to get the heating going.
I'm obviously going to have to drain the system to do this, but once done, I'll flush and refill the system with more corrosion inhibitor.
Which most speedfit fittings do when they are exposed.
