There are many shuttles to choose from out there...
Trust me i haved tried lots...
Depending on what level you play at determines the shuttles you should opt for...
Feathers are an expnesive item if you are just starting out or dont play too often.
The trouble being is if you dont hit the shuttle true you will destroy a feather shuttle with one blow of your racket...
If you want to try them then by all means do but do expect to go through a lot quite quickly..
Problem with feathers of a lesser quality is they do not last very long so lets say you buy a tube(dozen) cheap shuttles for around £8-10 you wont get much life out of them.
I play a lot of club badminton and we use all the Wilson range.. from the topline 70s to the topline 100s..
My friends and i use topline 90s .These retail at £13.99 dozen .
We buy 4 dozen between four of us and they last a good 3 months.We play 3 times a week..
Few tips if buying feathers do pre steam them a good 24hrs before play this prolongs the life of the shuttle...And use the broken or raggedy ones to warm up with...
It is like everthing in life you only get what you pay for..I have tried lots of cheap brands and the shuttles dont last a minute..
There are also many great makes other than Wilson ..
Yonex,Yehlex,Carlton,RSL...
Have a look on Central Sports Website they are always pretty competitive price wise..
And good luck..Once you use feathers though you will never want to go back to plastic..(although as someone above has mentioned the Mavis 2000s are as close as you will find to feather but they are as expensive as feather so dont really see the point)
