Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
Some of the bugs in this game are really starting to **** me off now. AA doesn't work at all, even if you ******* force it, same with vsync which is even more annoying. Theres no option to turn off the rubbish double tap sprint instead of just using shift which gets me killed at least 5 times per game and the glare bug on one of the conquest maps makes it basically unplayable.
Aye the glare on atacama is pathetic, its one of those things were you tear you hair out wonder HOW this wasn't raised as an issue by the monkeys internally testing it. Though since it wasn't raised as an issue i can only assume their testers are blind or they don't exist.
The crosshair on tanks and helis gets lost in the glare all the time, more so for the russians though.
Sooo , what do I need to do now?
EDIT: Why is the "tuner" bit of it greyed out.
EDIT2; , Going to try AMD overdrive
gigabyte may not support the tuner option for that perticular motherboard.
did you select the motherboard on the website first and was it availble under downloads for your perticular one?
ps looked it up the model listed in the PIC, Supports EasyTune(Note 4)
(Note 4) Available functions in EasyTune may differ by motherboard model.
so you may have to overclock manually if possible from the bios.
PS look at this link http://www.hardwaresecrets.com/printpage/721
do a find on web page for the info on overclocking.
PS continue this in the Overclocking forums as this is game chat , good Luck if your going to try an overclock. Be carefull.
the gold/bronze ones are from higher ranked players the silver/brones ones same rank and silver below your rank i ithnk
what double tap sprint?:confused:
Don't know but I wish they'd fix the CTG* bug which I always seem to suffer from whenever I enter a helicopter.
* Crash to ground :p
You have to install a bugfix called 'L2P'.
It also helps if you listen to Foo Fighters: Learn to Fly* while playing BC2 :p
*results not guaranteed unless you are Dave Grohl
