a rig like that needs 4GB, I would personally go for 2 x 2GB, but since you already have the 2 x1 GB just have to run it without dual channel, it's a small loss in performance I believe.
Why does he have to run it without dual channel mode?
He installs another 2 X 1gb kit and it still works on dual channel mode.
If he installs 2 X 2gb kit for 6gb total, it still runs in dual channel mode.
I guess so but having all slot occupied will stress the bus won't it? Reducing chances for higher overclockability.
Nope, all varies on type of memory and the controller.
Also dual channel only works if the memory slots are filled with the same capacity and speed ram. I think some of you need to read up: http://en.wikipedia.org/wiki/Dual-channel_architecture
why oh why did you install 32bit?
