- 28 Sep 2003
- Leamington Spa
Ok, so I think this likely to be pot hole related
Late last week I noticed that I could hear my car making an odd knocking noise on each rotation of the wheel. At the same time I noticed the left rear tire was always loosing a lot more pressure than the others each week.
I've arranged for someone to have a look at the wheel this weekend (I assume it's got warped from a pot hole), but in the short term as long as I kept the tire inflated, the noise went away, and I could feel nothing strange through the wheel.
Now this morning, I noticed a different noise, quite a bit louder, I can feel it through the wheel at times too. I've not been able to pin it down exactly but it seems load sensitive (different volume depending on which way I turn). It also seems to vary with speed. The one that has confused me a little is that if I lightly press the brakes, it will make the noise instantly every time.
I need to limp home from work on it tonight, but was going to take the wheel off at lunch and have a quick poke around to check the obvious . . . any ideas?
