4th month into ownership, 7000 miles and a set of tyres later and my car has decided it doesn't want to lock
When I press the button to lock it the car locks, you here the locking mechanisms working as normal then the thingys in the door pop back up. Locking via the key and pushing the door pops down all engage the central locking so it causes the same affect.
Also the little red light which normally flashes to show the alarm is armed doesn't flash at all now, so I'm guessing it might be something to do with that?
It's very unnerving as I'm in South London today and not in the nicest of areas
- Although I've left no valuables in the car.
Spoke to -westy- who suggested disconnecting the battery to try and reset the ecu/alarm, apart from that any other suggestions? I'll be doing these tomorrow as I'm not working then.
Cheers,
Jake
- Although I've left no valuables in the car. Spoke to -westy- who suggested disconnecting the battery to try and reset the ecu/alarm, apart from that any other suggestions? I'll be doing these tomorrow as I'm not working then.
Cheers,
Jake
and a local decent Rover breaker too
