Where could I find a 100mg weight?
9 Jun 2006
Purgatory
I need a 100mg weight to calibrate my 0.01g acurate digital scale. Can any OCukers advise me where I can find such a thing? Online or in store I don't mind.
Weigh several folder pieces of paper, say 10g worth, and work out the area required for a piece to weigh 100mg. Carefully cut it and go from there.
Alternatively, a sheet of 80gsm paper would require a 35.3mm square piece of paper for 100mg. It should be pretty accurate too.
I don't think you will find a 100mg weight, the thing would be tiny, I would imagine just touching it would add several mg of dirt.
What could you possibly be measuring in such small quant.... ohhhhh. :P
Maybe he's the only person in Britain who has a small digital balance who actually uses it for something other than drug dealing?
And for the OP: try Fisher Scientific, Cole-Palmer or VWR. They're pretty pricey though.
M
Search for calibration weight.
Before you buy, read up on which standard you need or want eg. M1, F1. The standards define how accurate they will be.
100mg E2 ~£25 + VAT
Ask your local dealer where he gets his callibration stuff from so you can get a group discount. Seems the obvious answer :D
