ATI 10.3 drivers wiill not install
6 Apr 2009
Liverpool
all it says is driver install: the inf file was not found and gives me a error log..its for the vapor x 5870 oc version...anyone got any ideas thanks.
well used the unistall program that came with it and a program called driver sweeper from guru 3d...is there any other utils i can use to check this thanks
this is the error i am getting
Catalyst™ Install Manager
Installation Report
04/01/10 20:31:18
Hardware information
Name ATI Radeon Graphics Processor
Manufacturer ATI Technologies Inc
Device ID 0x6898
Vendor ID 0x1002
Class Code 0x030000
Revision ID 0x00
Subsystem ID 0xe140
Subsystem vendor ID 0x174b
Other hardware
Existing packagesCatalyst Control Center
ATI Catalyst Install Manager
ATI Display Driver
Microsoft Visual C++ 2008 SP1 Redistributable
Catalyst Registration
AMD Drag and Drop Transcoding
Packages for install
Catalyst Control CenterFinal Status: Success
Version of Item: 2010.0302.2233.40412
ATI Catalyst Install ManagerFinal Status: Success
Version of Item: 3.0.765.0
ATI Display DriverFinal Status: Fail
Version of Item: 8.712.0.0000
HDMI/DP Audio DriverFinal Status: Fail
Version of Item: 7.11.0.7703
Communication Opt-inFinal Status: Success
Version of Item: 2.02.0000
AMD Drag and Drop TranscodingFinal Status: Success
Version of Item: 1.0.20
Other detected devices
Device ID 0xaa50
Vendor ID 0x1002
Class Code 0x040300
Revision ID 0x00
Subsystem ID 0xaa50
Error messages
Driver Install: the INF file was not found
Driver Install: the specified driver package was not installed for matching devices
ok i have them installed....i installed the catalyst and it said inf file was not found so i then went to the device manager and it said it was a standard vga card...so i then installed it from there and pointed it to the ati folder and pointed it to the driver from there...problem now is battlefield bc2 will not play it keeps crashing and showing like a grey/green screen with thin pinstripe lines down it...is it possible i need to install that game again thanks.
Classic example of DriverSweeper messing things up & is the only time that i had that inf problem was when i used DS.
See if you can system restore to the old drivers before the DS & then install the new drivers right over the top, it worked for me.
ahhh see i worked it the other way i was just about to format my pc.....think ive fixed the bad company 2 as well turned vsync off.....what does that do anyway lol
sounds more like the setup isn't extracted properly to me i have had same issues before and a redownload of the driver sorted it never had a single issue ever with driver sweeper and ati drivers
Vsync limits frames per second to the monitors refresh rate to help eliminate screen tearing a sort of graphical corruption of lines on the screen
so most lcd now are 60hz = 60 fps max with vsync on
