Best Value I5 or I7 Build
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) - Retail £199.99
(£170.20) £199.99
(£170.20)
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard £154.99
(£131.91) £154.99
(£131.91)
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK) £135.99
(£115.74) £135.99
(£115.74) Sub Total : £417.85 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50 VAT is being charged at 17.50% VAT : £74.79 Total : £502.14
or
Intel Core i5 750 2.66GHz (Lynnfield) (Socket LGA1156) - Retail £169.99
(£144.67) £169.99
(£144.67)
Gigabyte GA-P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard £102.99
(£87.65) £102.99
(£87.65)
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) £95.99
(£81.69) £95.99
(£81.69) Sub Total : £314.01 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00 VAT is being charged at 17.50% VAT : £56.53 Total : £379.54
Your sig is to big, max 4 lines.
You have not really given much information.In short both processors are very similar on gaming peformance so if you want value for money go and just do gaming go with the i5.
Should be able to, others to look at are P7P55D I believe is a good board, but it will increase the the price by £20 ~
Think I have to go with asus as i have crossfire and a essence stx and the only place it will fit is in between the to graphic cards which will be really tight, all gigabyte designs are the same
