- 9 Jan 2008
- London/Camberley
so it can defo run 16x, 16x, 16x? (fingers crossed)
No it'll run at x16/x8/x8 unfortunately. There is no NF200 chip.
your words make me sad - oh well its ordered now
 . Hope that makes you happier!
. Hope that makes you happier!That's £20 cheaper than what I budgeted for, so I'm pleased with that. Helios1234, thank you for the review, I'll read it shortly.
Excuse the ignorance, but what disadvantages could a user encounter with the PCI-E lanes running at 16x/8x/8x instead of 16x/16x/16x? Take me for example, I will be running a single 5870 on this board at first looking to upgrade to CrossFire later in the year, this won't be a problem for me will it?
For single or dual card setup, there'll be no problem and you'll be able to make full use of the PCIe x16 slots. For 3/4 card setup, people might feel that the reduced bandwidth of the x8 slots will reduce performance compared to x16.
In fact, I'll give it a go and report back. The second slot defaults to x8 so I'll see how the my GTX260 performs when I use it.
Great, thanks for doing that.I just tried running my GTX260 in the x8 slot and there was minimal impact on performance. I'll add the results to the review.
It will definitely run x16/x16 in dual Crossfire/SLi.
Hi
I take it the PCI-E lanes not running at full 16x is only a problem for a three card setup???? and a dual card setup SLI will defo run at full 16x???
Thanks for responding
Apologies for the barrage of questions, but do you happen to know what memory multipliers are available for selection?
