HP ZR24W 24" WIDESCREEN LCD MONITOR AVAILABLE TO PRE-ORDER
17 Oct 2002
Stoke
HP's new premium panel is available to pre-order featuring a DisplayPort connection and S-IPS panel for improved colours.
HP ZR24w 24" Widescreen LCD Monitor @ £329.99 Inc VAT
The ZR24w delivers outstanding visual performance with its S-IPS panel for enhanced colour accuracy at ultra-wide viewing angles, 16.7m displayable colours, 1920x1200 resolution, 7ms response time and 3000:1 dynamic contrast ratio. The HP ZR24w enables maximum comfort and best visual positioning with an 8-way comfort adjust stand that provides tilt, pivot, swivel, and column height adjustability, so you can increase your comfort and productivity throughout the day.
- Height Adjustment: 100mm
- Swivel Stand: (45° Left & 45° Right)
- Tilt Angle: 30° Up & 5° Down
- Screen Size: 24" S-IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 3000:1
- Brightness: 400cd/m²
- Response Time: 7ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x VGA, 1x DisplayPort & 1x DVI-D
- 4-Port USB Hub
- Adjustable Stand
- VESA Compliant
- Dimensions: 556.0mm x 425.0mm x 235.0mm
- Weight: 8.5kg
- Warranty: 3 Years On-Site
Only £329.99 inc VAT.
ORDER NOW
