- 7 Feb 2004
My offside rear wheel is not spinning freely, I noticed the other day whilst driving it and after I stopped there was some heat coming from the wheel.
Normally if anything goes wrong I take it straight to a mechanic but I thought I may just have a quick look myself as I thought it may just need a quick strip, clean and copper grease.
I jacked and chocked the car and the wheel was indeed very difficult to spin, after I (eventually) removed the wheel I was confronted by the image below.
I presumed the next step was to unscrew bolt 'A' however the rubber cover 'B' started to twist so I put a spanner to hold nut 'C' then started to undo bolt 'A' again, this seemed to do the trick as the rubber didn't twist.
At this point I realised I wouldn't have enough time to go much further so tightened it back up and put the wheel back on.
Is this the right procedure and any tips on freeing it up?
Cheers
Cheers
