- 5 Aug 2006
- Derbyshire
As title, I am after a 5870 from MM. Just before I buy, I would like to know if a tagan 480w psu is enough for this card.
I know power requirements are massively overestimated (sometimes by 100's of watts). The psu in question is a tagan bought from ocuk 18-24months ago and was amungst the expensive brands like corsair in in terms of pricing. The PSU has two 6pin pci-e power adaptors on it (enough for the 5870).
The pc in question has an i5 750 which will be clocked, a few case fans, a dvd-rw and one mechanical hard drive.
I have checked reviews and the total system power consumption under load is below 400w. Just wanted to check with you lot before I buy.
Thanks!
Thanks!
