You can overcome that issue by removing the upper part of the heatsink in the offending module(s), like this:
I doubt the RAM's cooling abilities will be affected much at all, especially if the case is well cooled to begin with. Go on, you know you want to...![]()
i would be a little bit concerned with removing the heat spreadder's fins? is that the only option?
cant you mount the h/s horizontally?
