i5-750 cooling
29 Mar 2010
Hey guys, need some more advice...
I am building an i5-750 rig, and would like to know which coolers would be suitable.
I am planning on a heavy overclock, but I have the limitation of only one rear 120mm case fan (mesh side panel and intake fan on the front help keep it cool, but this makes water cooling kits difficult)
Any suggestions?
there is about 140mm between the mobo and the case side, so not enough for the megahalems.
I read a review of the corsair H50 that said the fan had to be set up to blow air inwards, which meant it was unsuitable for cases without a secondary rear exhaust fan - is there a way around this without cutting up my case?
The Noctua cooler in my sig is awesome and can be had for just over £50 if you shop around.
I am currently running IBT and Prime at the same time and am under 70c at 4ghz. Cooler is very quiet too.
That is the corsair recommended way of doing it, but you can just mount it as an exhaust. It doesn't perform quite as well - but it's still darned good. Here is a review which compares the two ways of mounting - and shows the effect of a 2nd fan.
